CDA's - setup and how they work
Does anyone have any resources on CDA’s and how they are setup and work in NW?
Yes, good question. I was able to:
  1. Create a master profile
  2. Load the profile
  3. Added the fields to the profile
However, could not go any further, because I do not know how to load the profile for the table nor app. Does anybody know how to do so?
Nextworld Help has fairly exhaustive documentation on CDAs that I think covers basically everything. Have you been able to review it or looking for additional content above and beyond it?
Hey Ian, yes, I believe there’s a lot of documentation but can’t seem to find exact steps on how to set it up. Maybe I am missing a piece of the puzzle, because there’s quite a few of those notes. I need to understand why the table and app isn’t loading the profile that I created… Do I need to extend/customize the master table that I listed in my profile? Do I need to do anything with the application that is over that table to assign the profile to it? I tried loading the config, but that did not pull it into the composite apps other than the app where I could select the data items I created.
Book time on my calendar if you wouldn’t mind @stefanus so we can do a deeper dive on what might be missing: Bookings with me
Many thanks @ian.p , I made a booking for today, much appreciated!
If you learned anything that would be useful for others, please update this thread with your findings!
