Delivered Data Questions
I have some questions on delivered data. Our help text says delivered data moves downstream automatically with each patch, so I want to confirm that is still the case now that Nextworld has moved to a continuous delivery model.
Also, the original guidance when the delivered data feature was made available was to make changes to delivered data records at major release boundaries to minimize tenant disruption. Does that guidance still apply, or has the thinking around that changed given how frequently patches are going out now?
Lastly, where is the proper place to create your Delivered Data records (like Delivered Data Definitions, Delivered Data Setup, etc.). Would you create in your RP environment and use Promotion Manager to move downstream? Or should these be created directly in Test?
