Syntax for referencing specific data source payload in Message Templates when multiple input payloads are present
I am building a message template to send an email to a customer where the message event takes multiple input data sources so that it can reference content across multiple records. What is the proper syntax to use, so that my email knows when to reference fields from Data Source 1 vs Data Source 2 vs Data Source 3 from the Message Event Definition?
Qualify each placeholder with the data source name, separated by a dot:
{*DataSourceName.DataItemName*}
The part before the dot is the Name of the data source (payload entry) exactly as it’s spelled on the event definition — not the table name, not the label. It’s case-sensitive. So a three-source email looks like:
Hello {*Customer.CustomerFullName*},
Your order {*Order.OrderNumber*} shipped on {*Shipment.ShipDate*}.
The unqualified form still works, but don’t use it here. {*OrderNumber*} with no prefix is the legacy single-source syntax — it silently resolves against the first data source listed on the event definition. With three sources that’s a trap: reordering the definition changes what your template renders. Qualify all of them.
