Ability to Deprecate Interactive Reports
Hello - if we previously created an interactive report that we no longer need is there any way to deprecate this in the system?
Hi Melanie,
Yes, there is! You can deprecate Interactive Reports the same way you deprecate other metadata in our Platform.
  • Go to Interactive Report Builder and find the one you want to deprecate
  • Edit it
  • Scroll down to the Release Management section and select the “Deprecate” checkbox.
  • You can also optionally add a value in the “Deprecated Date” field if you’d like.
  • Save.
