Default Inventory Location
How is the default inventory issue location determined?
The issue location for material issue will default in the following order of precedence:
  1. Work Order Materials – The issue location defined for the component on the work order materials list.
  2. Item Inventory Location – The issue location identified as the default for the item org unit.
  3. Work Center – The issue location defined for the work center.
  4. Org Unit – The default issue location defined in the inventory module settings.
If you are looking for more information with an example. Check out the topic “Default issue location” in Nextworld Help.
