DID Popup Alert
Is it possible to trigger a notification popup once a DID successfully loads (similar to the executed popup when you kick off the DID). We configured a post file Logic block that sets a message with a type = popup notification. We can see this in the data import runs but would prefer a popup alert if possible.
Because Data Imports run as a background task the only message we can send is a bell notification. The notifications that appear in the lower corner or in an app can not be sent in this case.
We already send a bell notification when the import completes. Why is this type of notification insufficient for you case?
Thank you, the current bell notification does work. Trying to understand what else is possible.
