Export CSV functionality exporting Values instead of Description for list lookups
I have a list lookup that was defined incorrectly upon creation and we are now in too deep to just rip it out and replace it. The value and description of several list lookup options are jumbled around, and unfortunately this list lookup is for a workflow definition…
I was wondering if there is a way to define at an environment or table level (or even LL level) to say export description rather than value… Otherwise I think I’m looking at a not-so-fun workflow data transform to correct the values.
Context: The values defined on 3 critical WF steps are defined incorrectly (see below table). End users are exporting the records using this workflow and finding their filter for Open WF is pulling in RECEIVED on the csv.
Current Value Current Description New Value New Description
RECEIVED Open OPEN Open
OPEN Generated GENERATED Generated
COMPLETED Received RECEIVED Received
As far as I’m aware, this is not currently possible.
This is the list view Export CSV functionality, right? The workaround for this would be to hit the Report Quickstart button instead and then export the IR results - I’m pretty sure we display LL descriptions there. It’s just a few more button clicks.
This is for the Export CSV functionality. I showed the customer’s end users the report quick start button (and even offered to replace the export CSV with an app link to a custom interactive report that’s set up for them) and they did not like either one because you have to click “Download” in the report for both rather than the export CSV immediately downloading once available
