Extended Mapping Search
Hi there,
If one goes to a list of Extended Mappings and wants to filter on the Extended Driving Class Group, the popup for the filter shows, but the list lookups don’t populate. Should we have the ability to filter on the extended driving class group using this search popup?
Thank you.
Can you please provide some reproduction steps for this so I can understand how you are getting to whatever screen you are on?
@ian.p
  • Go to a GL Mapping Rule which has Extended Mappings setup.
  • Try search for a particular mapping with a particular LL value in the Extended Driving Class Group - I clicked the 3 dots next to the search field (refer to screenshot below)
  • A box pops up, but the List Lookup values are not populated, so you cannot search (refer to screenshot below)
Please let me know if you require more info. Thank you.
This should be supported, it looks like a platform bug where the list lookup options are not getting loaded properly.
@kyle.pecci Do you want me to submit a ticket for the above?
Yes please end a bug for platform!
