If I call /v2/Authenticate/Tokens with valid credentials but pass in an invalid value for Tenant or Environment or Lifecycle, how does the platform respond to those invalid inputs?
I assume you are talking purely about /v2/Authenticate/Tokens, not with the additional query params ?login or ?refreshas the behavior is different.
If you have an invalid Tenant, Environment or Lifecycle you will get the following responses respectively with a 401 code:
"ErrorMessages": [
"ErrorType": "Error",
"ErrorSubType": "nwsysauthenticationexception",
"ErrorCode": "TOKEN_REFRESH_FAILED",
"ErrorDescription": "Token refresh failed. Caused by: Invalid tenant for user: <tenant name>",
"ErrorStyle": null,
"ErrorPayload": [],
"ErrorTechnicalDetails": null,
"ErrorDetails": {
"LogicBlockStackTrace": []
"ErrorFields": [
"ErrorMessages": [
"ErrorDescription": "Token refresh failed. Caused by: The environment <environment name> is invalid for the tenant <user tenant>.",
"ErrorStyle": null,
"ErrorPayload": [],
"ErrorDetails": {
"ErrorFields": [
"ErrorMessages": [
"ErrorCode": "TOKEN_GENERATION_FAILED",
"ErrorDescription": "Token generation failed. Caused by: Invalid lifecycle.",
"ErrorStyle": null,
"ErrorPayload": [],
"ErrorDetails": {
"ErrorFields": [
