Identity Insert
Is it possible to insert a record into a table/subtable(main) using its original nwId? Similar like a SQL Identity Insert?
Use Case: We have a subtable with records, however, these are not sorted. We have logic to extract, sort and reinsert these in a sorted order, but this creates new nwIds which breaks referential integrity.
Ideally we would like to reinsert these with their original nwIds to keep any existing data happy.
Any thoughts?
I’m not sure this is possible, but I would like to understand more about the Referential Integrity setup that involves the Subtable records - can you elaborate on that?
Ian is correct. The platform does not currently support this concept. Even if an nwId is provided to the insert the provided value will be discarded and a new nwId created.
Thanks for the quick reply.
We are storing a setting/code in a subtable(main) and referencing the subtable.nwId as a TL on the another table. We had a request to sort the setting/code - I tried the extract, fetch sorted and insert method but this breaks the references on the other table so we abandoned the idea. That’s the reason for the ask.
