Is there a way to track UI usage analytics for apps built on the platform?
Is there a way to capture UI analytics for apps built on the platform so I can get visibility into how end users are interacting with applications (for example, which features are used most, where users are dropping off, etc.). The goal is to help evaluate usability and determine where improvements are needed.
Does the platform currently support anything like this?
  • Built-in UI analytics?
  • Ability to track user behavior (page views, button clicks, etc.)?
  • Integration with third-party tools like Mixpanel, Hotjar, or others?
The platform currently supports an integration to Google Analytics on a per-tenant basis. A Google Analytics key can be set up in the Nextworld API Keys application, and usage analytics data will then be captured by Google.
The platform does not support an integration to other third-party tools such as the ones listed above.
