When creating an Interactive Report with different versions, should one be able to switch between a version that is setup with a table which has a group setup (with aggregates) and a version which has a table that is not grouped?
I am having an issue with the above scenario, so wanted to check first before submitting a ticket.
Thank you.
Yes; there should be no issue doing this. Assuming all report versions are individually valid, there should be no reason you cannot switch between them regardless of how they are configured. What issue are you running into?
@calvin.fisher If I have 2 versions and one has a grouped row specified and the other not, it does not seem to change the version. I have submitted a ticket. Thank you for getting back to me on the above.
Yep, that sounds like a bug to me in that case. Thanks for filing a ticket!
