Is there a way to display the selected values from a multi-select list lookup in the Log Messages of an Interrupt With Error action in a logic block?
Yes, this works. In a logic block with Interrupt with Error action, you can add an entry to the log data section that contains Field → [your Data source] → [your multi-select LL] and the error will throw with the full list of selected entries.
Is this in 25.2? Or should it work in 25.1 as well?
This works 25.1 and onward ![]()
