If I have a logic block which is kicked off via a row action and the logic block creates a customer invoice/supplier invoice/receipt, etc - is there any way to navigate to the newly created record using the nwId after the action logic block is called in the LB called from the row action?
For example, a logic block creates a customer invoice by calling WriteReceivableTransactions. Is there a way one can navigate to that customer invoice after the nwID is returned from the WriteReceivableTransactions logic block? I know about the Queue App Link, but we don’t have the mappings available yet, so want to understand if this is scenario possible and if so, how one goes about implementing something like this.
Thank you.
Hi Claire,
The Queue App Link should work to get any record that you have enough information to navigate to. You mentioned you have the nwID returned; have you tried to use that to fetch the newly created record and pass the mappings in? Or is that what you mean when you say the mappings aren’t available yet?
Best,
Caroline
@cj_fusch I would like to do this same thing navigate away from my record upon completion of another process but not from a row action. My process is driven by workflow orchestrations and I would like to automatically navigate after a save which causes my record to reach a particular status. Quick example would be when my Return Order reaches a completed status to automatically bring up the refunds application so I don’t have to click to do the thing I’m going to do 99.9% of the time.
