Can I call a Test Action from within another Test Action?
Actually, yes. Select ‘Utilities’ and ‘Import a test action’. This is an old feature that isn’t really used much anymore. But it should work.
You can also use the same test action multiple times in a test flow, ff that fits your use case better.
