Remittance AI Documentation
Hello, I am trying to learn more about how to utilize AI in Nextworld development. To this end, I am trying to dig into how the Remittance Advice application works. The help section on this application did not indicate which agents are used and I am struggling to find any searching myself. I also haven’t been able to find anything helpful logic blocks digging through the process myself.
Hi,
The Remittance Advice application will read an attachment on the record (PDF, JPEG, PNG, etc) and ExtractRemittanceAdvice (Logic Block) will run using two different models depending on what type of file. ExtractRemittanceAdviceDefinitionWithVisionModel (JPEG, JPG, PNG, WEBP, GIF, TIF, TIFF) or ExtractRemittanceAdviceDefinition (PDF) these models will then out put into a DSN to be used to set values on the record/table based on the model output. Please review the logic block ExtractRemittanceAdvice and those models and let me know if you have any more questions!
