Subtables usage within applications
Morning all,
I am trying to find out if anyone is having issues with displaying subtables within applications?
We have a subtable of type Subtable Main. That is linked to a subtable Data Item, That Data Item Was attached within a Detail Table that was then meant to be used on a Detail application.
When you go to the detail application (Which is owned) we added the Data Item to a new row lets say G, and when you set the Subtable fields to be visible nothing happens.
Now in testing we did change the subtable type to Sub, then reapplied to the Data Item, Table and then application and in that instance it seemed to work. Is there a new requirement that all subtables are set from Subtable Main to Sub?
Changing from type Main to type Sub may have seemed to work, but that is not an acceptable way forwards for this issue @pbarber . Can you please move the discussion on this to a Freshdesk ticket so it can be treated like a bug?
I was hoping someone was going to say bug. I’ll get this moved
Hi @ian.p Do you know if this got resolved? I have a similar use case and I’m also not seeing the subtable fields on the application.
I can’t find subsequent history on this topic so I’m not sure. Please submit a ticket yourself if required.
Thanks @ian.p . Will do.
