Are there any plans to add support for Base64 encode/decode of a text variable in a Logic Block? Perhaps via additional types of operations on the Text Manipulation action? We have a case where a type of dealer ID (dealer Fusion ID) is base64 encoded into a setting and requires us to run a base64 decode before we have a value we can use in certain API calls.
This is not something that the platform currently supports, but it’s certainly possible to do.
If you’re a Nextworld customer or partner, please with with your associated support team to create an enhancement request and provide some more context for how you would want that action to work. If not, keep an eye on release notes - we’re always building new features!
