Is it possible to easily test a Semantic Search directly without hooking it up to an agent or logic block?
A bit like the Try It Out tab when defining a Prompt Definition.
Hi Ian, the Embedding Configurations application has the row action, Search Embedded Content, that allows you to do just that! Not sure if you’re able to test with any specific filters you apply on an associated semantic search though.
OK I didn’t see that. Having first worked in Prompt Definitions and seen the Try it Out tab I wasn’t expecting there to be an app link to test the feature, which given it’s the 2nd form action of that app, isn’t obvious to the end user.
Confirming what Aaron wasn’t sure about. There is no way to test a semantic search that applies the filters from the semantic search level. This feature enforces embedding level filters, but will not apply filters that are defined at the semantic search level.
