How can I validate multiple fields on multiple records in a list view? i.e. I’m trying to validate multiple records, but I’m validating the same fields on each record. Do I have to filter down to one record and record steps in my test action for each record, one at a time?
Yes you should always filter for each individual row, and do your validations at index 0. The reason for this is that we can never guarantee the order in which records are returned from the DB. You might be tempted to rely on an application’s sort. But what happens when that sort changes, or new seed data gets added. It is tedious but crucial to avoid an unstable test. This might actually slower than recording all of the filtering and validating, but you could try recording all the validations at once, and then manually insert your filter steps, and remove the set context step that will get inserted for each row.
