am looking into year end transactions, such as Audit Adjustments. My understanding is that these transaction are typically transacted against the 13th period.
In the help files I found that the transactions type ‘Audit Adjustment’ will be use. In the JWB, adjustments will be posted against the 13th Month Adjustments . Will the latter replace the ‘Audit Adjustment’ transaction type?
Should the 13th Month Adjustments only be used for adjustments at the end of the fiscal year.
- Reason for asking: I am able to post using adjustments in any open month, with the Journal Source
To create open balances for the next financial year, the
Create Year End Close Entryshould be executed. This is probably executed when the financial year is completed, but no tax prep yet.-
Audit adjustment entries are typically added after the tax return is completed (months after the original closing entries were created)
It seems that after the audit adjustments have been entered the next actions for the previous year closing:
1st closing entry transaction should be voided, and then rerun
Create Year End Close Entry. -
Is this the correct process to included the adjustments in the open balances for the next financial year?
