25.2.13 Release Note Summary
Patch 13 (25.2.13) — Platform & Platform AI
:green_circle: High Value
  • Project Builder: Move Projects Between Environments with Metadata Manifest—Select a project in the Metadata Manifest and expand it into all the objects created within it, then move it with a Metadata Sharing Export Utility record.
  • Project Builder: Delete Artifacts From Your Projects—Delete an artifact and its associated objects from the Artifact Action menu, with a checkpoint created automatically so you can restore it.
  • Project Builder: Configure Search Applications—Every table lookup field now has a working search app by default, with single-click selection, configurable fields, and filters to restrict results.
  • Project Builder: Add Gantt, Calendar, and Spreadsheet Views to Existing Apps—Gantt, calendar, spreadsheet, Kanban, dashboard, and list views are now formally supported, so you can ask Ed the Builder to add or update them and get consistent results.
  • Agents: Query and Aggregate Data More Flexibly—Agent queries now support paging and distinct values, and calculate sum, average, minimum, maximum, and count directly in the database, so totals on large tables are faster and complete.
  • Agent Skills: Attach Files to a Skill—Attach files to a skill in Agent Builder so its instructions can reference them, and the files travel with the skill when you promote it or export it.
  • Ed: Read Image Files in Conversations—Ed can now use attached PNG, JPG, JPEG, SVG, and PDF files to answer questions or complete tasks in Header Detail and Standard applications. Before, it could only read PDFs.
:yellow_circle: Notable
  • Agent Conversation Inquiry: See What Every Agent Did, and Why—Open any conversation next to its trace to see each step, the skills and tools used, and any errors, then choose Debug in Ed to dig into a run.
  • Project Builder: An Infrastructure Update for Existing Projects—Update an existing project to shared Project Builder infrastructure so fixes land once for every app, and dates near midnight no longer show the wrong day. New projects get it by default.
  • Project Builder: Data Model and Table Viewer Enhancements—Select a table to see its fields and its contents in a read-only, filterable list, within your existing security.
  • Data Imports: Choose a Delimiter for CSV Files—Pick Comma, Pipe, Tab, or Semicolon for CSV imports, including SFTP imports (also backported to 25.2.11).
:white_circle: Bugs & Small Features
  • Project Builder: Merge Projects Within a Lifecycle—Merging a project’s objects into a lifecycle no longer produces merge conflicts.
  • Managed Tenants: Notifications Send Correctly for Managing Tenant Admins—Notifications from background jobs run by an administrator in a managed tenant now surface correctly.
