Adding a LB to the first subflow transition
Is there a way to run a LB on the first transition into the subflow. I see you can on the “transitions” page but by that time the record has entered the workflow defined in the “subflow config” tab of “starting workflow state/state type.” i dont see any place to attach logic to that first transition out of the base workflow into the “Starting workflow state/state type.”
As far as I’m aware this is not currently possible.
Can I put an enhancement in? It seems like a transition into a subflow should support all the same functionality as the rest of the workflow transitions.
I think putting an enhancement request in for this via Freshdesk is valid.
Thank you. https://support.nextworld.net/support/tickets/437523
