When generating my application, I no longer see a corresponding Jobs record tracking the generation?
In most cases, application are now generating inline.
When you generate from app builder, you will not see a job anymore. This is because it is not a background, task - it is just initiating a logic block process when selected. If it errors, you’ll see the error at the top of the screen.
If you generate from the Navigation menu, a Generate All, or you generate related apps with a row action, you can see a result in the Jobs table. If there are errors, that is also where you will see them.
