Application Title When Entering Through Different Methods
From a list view, I have two different application links targeting the same application:
  1. Create Override to enter the header/detail view
  2. Double-click Override to enter the header detail view
However, I would like:
  1. when I enter the application from the Create Override, for the application Title to say New Form
  2. When I enter the application from the Double-click Override, for the application Title to say View Existing
How do I achieve this?
You would need two different app links and you would data map the different titles in those separate app link. The source would be a constant and the destination would be title.
@joeyates23 got it! There is a dedicated “Title” selection when creating mappings through an app link. On the Actions tab of the application builder, you can select the “Create Mappings” or “Edit Mappings” for the app link and establish a title in addition to any other data mappings from the source to target app.
