Auto Creation of Application Customisations
Hi there,
Can I confirm that when a patch lands/updates are done in the environments, customisations are automatically being created? This is what I am seeing, but wanted to check first.
And, if this if this is the case, is it possible to “turn off” the creation of the customisations in certain environments when a patch lands/updates are run in the environments?
Thank you.
Hi Claire,
Yes - certain apps are auto-customized by the system based on Solution dependencies. They are created when a Solution is activated (or reactivated) which happens every patch.
There is not currently a way to deactivate this behavior, but we are working on removing this requirement so that behavior will go away in the future.
Thank you, @victoria - do you know when that will become available?
Looking at the next ~3 months!
For future readers, application customizations are no longer being created as part of solution activation as of 25.2.04. SD Partner announcement: https://community.nextw.com/t/25-2-04-eliminate-the-need-for-customizations-for-extended-applications/1609?u=ian.p
Release note: RN-25.2.04-[NextbotBase]-5410
