Automating Save and Stay
Can we automate save and stay through logic block conditionally instead of manually clicking on save and stay?
Ask is to select workflow as Post and then it should automatically save and posted.
Current behavior is user has to select post and then click on save options.
Alternatively, Can we trigger save and stay on change of any fields as well?
Triggering Save and Stay based on an event in a field is not currently possible.
However, it is possible to to execute a manual workflow change and save at the same time. Hold down the Shift key on Windows or Option key on Mac while selecting the desired workflow transition. See release note RN-24.2-[Nextbot]-5413 for further details.
