Can I display a base NW field on an application extension?
Can I display a base field’s table lookup value on my application extension. For example, I’ve extended the Sales Order Header and want to display the CustomerName_CustomerClassification table lookup field on my extension page. Is this supported?
For an extension, you can put fields from your extension application on one of your extension pages. You can put extension fields with base fields in the header or the footer of an application.
