Can Role Relationships Be Exported Using Metadata Utilities?
Is it possible to export and import role relationships using the Metadata Sharing Export/Import Utilities? If so, which BundleMetadataType should be selected to include them?
If not, what’s the recommended approach for moving role relationships between environments?
The role relationship is not technically tagged as metadata so you cannot use with metadata sharing. We do have an idea in the backlog for this.
Thank you, @viviana.s! Looks like the guidance in the meantime is to manually recreate the role relationships in the target environment or export/import the role relationship table directly (although this is pretty challenging so most teams go the manual route).
@bethany.k you are correct
How would I go about exporting/importing the role relationships? I am not sure which tables I would need to consider when trying to do this.
The role relationship is stored in a table called RoleRelationships
