Can I metadata share between releases? For example, I’m working on an application in a 24.2 tenant. We are about to be upgraded to 25.1. Can I export the metadata from my 24.2 tenant and import into a 25.1 tenant after release upgrade?
Hello @michael.w , the Metadata Sharing feature allows metadata to be exported & imported within the same release, or up one release. In your example, metadata can be exported from a 24.2 release environment and imported into either a 24.2 or 25.1 release environment. We do not support migrating down a release (25.1 → 24.2 is not supported) or up two or more major releases.
