Currency Fields on 25.2: Value Attribute not Selectable
Question for 25.2 Currency Fields:
On IF/THEN conditions, we only see the Code Attribute selectable; Value is no longer available.
Is the Value now the default unless you specifically select Code?
I was looking around in Release Notes and other docs and conversations but haven’t found anything about it.
There was no release note for this but I can confirm this was an expected change.
If you want to compare to Value leave the Currency Attribute empty moving forwards - meaning it’s the default when empty like you said.
