Endpoint Documentation as a json export
Rather than paging through the Endpoint Documentation I would like to be able to export all the end points into its JSON Swagger like representation. Or whatever is exported that is not so UI heavy
The platform doesn’t support that currently.
If you are a Nextworld customer or partner you can also work with your system administrator to submit an official enhancement request with customer support. Include a link to this post in the support ticket. If you’re not a Nextworld customer, keep an eye on release notes. We’re always making improvements.
See @kendra.b’s next post, I was unaware of this capability.
Nextworld’s documentation conforms to OpenAPI standards. To get the OpenAPI content in its raw (yaml) form you can call the documentation endpoint. That endpoint is also documented in the Endpoint Documentation under the Documentation heading.
