Endpoint logging retention period
What is the endpoint logging retention period? We have logs that we wanted to review from May.
There is a daily job that purges records from tables like Endpoint Logging. The default time before purge for standard logging tables like Endpoint Logging and Jobs is 30 days.
The Purge Configuration application has more information on this but requires special security access to view or edit records.
Purge Configuration seems to be empty in customer environments. I assume there is a default one behind the scenes for BASE objects and purge configurations can be setup for owned items. If we would like to change it to 60 days, would that be possible in a customer environment?
The platform doesn’t currently support changing these values within a customer environment. Purge Configuration records are currently only editable in _base tenants and there is no Owned customization support.
If you are a Nextworld customer or partner, you can also work with your system administrator to submit an official enhancement request with customer support. Include a link to this post in the support ticket. If you’re not a Nextworld customer, keep an eye on release notes. We’re always making improvements.
