Error During Cube Activation: Are Manually Defined Unique Indexes on Summary Tables Supported?
I encountered the following error during a cube activation:
[ { "Data": [], "Type": "Error", "Message": "A unique index is automatically generated for the summary data table upon activation. Therefore, defining another unique index manually is not allowed." } ]
After investigating, I found that the associated data table for this cube summary table has a manually defined unique index. Are manually defined indexes (especially unique ones) on summary data tables supported?
In this case, the issue was caused by a manually defined unique index on the data table. To resolve this, I had to update my manually defined index to Unique = False.
A few important notes I wanted to post that others might find helpful:
  • Summary tables can have user-defined indexes, but these must not be unique.
  • The platform automatically defines a unique index based on the dimension fields in the cube summary definition. This is required for processing summary table events.
  • Multiple unique indexes on the table will conflict, which is what’s happening in this case.
  • If needed, you can reorder the dimension fields in the summary definition to influence how the platform generates its default unique index.
  • You can also add additional indexes, but again, they must be non-unique.
