Hi who would be the system admin here? “ErrorCode”: “ERROR_EXECUTING_QUERY_LOCK_TIMEOUT”,
“ErrorDescription”: “Error executing query. The table and/or record(s) being queried is locked by another process and wasn’t released in a timely manner. See details for more.”,
“ErrorStyle”: null,
“ErrorPayload”: ,
“ErrorTechnicalDetails”: “If the problem persists, reach out to a system admin and give them this error ID: {SQL-EX-4b974c24-3f7f-4a94-9421-ab41f46eb4c7}”,
The system admin in this case refers to whoever was responsible for the logic that was running when this error occurred. Do you have a logic block stack trace to provide more insight into what was going on when this happened?
I was running this CURL to insert record into SalesOrder Table:
curl --request POST \
--url https://api-nw251coxintnext.releasepipeline.nextworld.net:443/v2/data/SalesOrders \
--header 'Authorization: Bearer ' \
--header 'content-type: application/json' \
--data '{
"records": [
"nateDisposition": "PRISTINE",
"appData": {
"Company": "505c4bfa-f104-11ed-892f-0d75d66845d9",
"SalesOrderType": "SO",
"OrganizationalUnit": "505c4bfa-f104-11ed-892f-0d75d66845d9",
"CustomerName": "817ac07f-c60a-46a5-bff7-f9a7c25f2e74",
"ShipTo": "505c4bfa-f104-11ed-892f-0d75d66845d9",
"SalesSubType": "nsCoxCOUNTERNS"
"children": [
"nwTable": "SalesOrderDetail",
"records": [
"appData": {
"Item": "0613b10a-9071-423a-a873-2f76a8352b15",
"RequestedQuantity": 2,
"SalesLineType":"STOCK",
"UnitOfMeasure": "nsCoxEA",
"DescriptionOfItem": "PART1A",
"PriceEffectiveDateTime": "2025-10-10T23:38:51.814Z",
"Price": {
"CurrencyCode": "USD",
"CurrencyBigDecimalValue": "9000"
"nsCoxFulFillmentMethod": "SO",
"nsCoxRepairOrderNumber": "4000015430",
"nsCoxRepairOrderPartSequenceNumber": "a5da1bbe-732e-498b-a0a6-a2b9cd2c4dd4"
"createContainer": true,
"commitContainer": true,
"containerPerRecord": false,
"containerType": "DEFAULT"
Please look at the response returned from that call to see if there is a logic block stack trace included.
Waiting to run into this again, it is an intermittent issue.
