I am confused what the purpose of the Default field is on Format Definitions. How does that field get used? In this image, two records are indicated as being the Default address format. Once it’s confirmed how this field gets used in what circumstances, which one of these two Defaults actually wins and gets used?
It looks like we use the last one that is marked as default in the list sorted by the Format Name field.
@ian.p This is a bug. You should not be able to mark more than one format of a given type as Default.
If you are a Nextworld customer or partner, work with your system administrator to submit a ticket with customer support, who will file a bug on your behalf. Include a link to this post in the ticket. If you’re not a Nextworld customer, keep an eye on release notes. We’re always making improvements.
