Address Field for Multi-line address without country
Is it possible to customize or create our own address field that is multi-line but excludes the country? We would like to use in our Reports. Alternatively we can add each line but preferable to have just one field?
@connor.hoffman read through this community post and see if it answers your question. I know you aren’t asking about a Canadian address, but I still think the answers apply to you.
If you still have questions, let me know.
@jillene.r I have currently marked the Country as Exclude from View. I believe this may solve the issue universally. But what about being able to have it as a field to display instead, that way we can use the same address format across the board but 1 report can print the multiline excluding country and another report can print the multi line w/country?
@jillene.r I noticed that the Format Definitions can have multiple Default Address Formats selected. Which one will it default to if that’s the case?
@martha or @tyler.pham could one of you answer this question?
Are you asking if there is more than one that is default which will it use? If that is the question somebody on platform would need to answer that.
I agree with Martha, someone on platform with previous knowledge would have to answer that — although I think that might be a bug/missing validation.
@francesca.faessler or @victoria would either of you know? I did a quick test but it’s inconclusive and I am not sure if it’s caching or not.
@connor.hoffman re:
I believe the ability to have multiple defaults looks like a bug. Can you please submit a ticket and include a link to this post regarding this?
