I have checked out a WF Defn to my LC. I go to edit the transition that I need to add an additional post transition logic block and the add is disabled. How do I add a new post transition logic block?
This is what I had to do to get it to be added. Not sure if a bug on the edit of a transition or if this is the new way to add logic blocks.
I added under the tab “Multi-transition Logic Blocks” a new sequence with the same transition criteria with the new logic block.
After saving, it appears on transition line.
I believe something about those transitions is making the system disable them because of something to do with customization. I’m following up internally on that. Is there an extended history for this workflow definition which might have involved customization in one of its past lives do you know?
As far as I know we have not had any customizations of this WF Defn. Audit shows no history.
