I have a row of information on the detail view of my app that I’d like to separate as a header row - what’s the best way to accomplish this?
In Application Builder, select a row and then use the Row Placement field to mark it as a Header or Footer row.
In addition to the how that @matt explained above, I want to point out that it is possible to have multiple header rows or footer rows. They will be sorted within the header or footer space by their Sort Sequence field, which is determined by where you drag & drop the row in Visual Builder.
