See attachement. In the “Receipt Information” section, I’ve moved all the fields into a single row so they collapse together. However, this causes alignment issues—specifically, the second fields in each column don’t line up properly. When I split the fields into two distinct rows, the alignment improves, but I can no longer find a way to collapse both rows at once.
CollapseMultipleRows.pdf (149.9 KB)
We currently do not have a way to do this because each row is independent of the behavior of other rows.
