What triggers a replenishment? And where do I configure it?
Replenishments can be set up for fixed pick items in the Fixed Pick Item Setup menu. The following can be configured:
- Replenishment Method
- Minimum On Hand Quantity and UOM
- Replenishment Quantity and UOM
- Maximum Stock Level Quantity and UOM
Once this is set up, replenishments can be set up as a scheduled job using the delivered “nsC7GenerateReplenishments” job scheduler record.
