This configuration is part of the email forwarding feature available for the platform. This configuration step occurs after you:
- Configure your Webhook Setup record in the Nextworld platform. Learn more in the Automate email forwarding with webhooks topic in Nextworld Help.
This configuration document provides shortcuts for creating a flow. There are code snippets provided which you can copy and paste into each action in order to recreate a flow created and tested by internal development. Once created, you can edit and change any components.
Power Automate Configuration for Emails with Attachments
Navigate to Power Automate and select My Flows from the Sidebar menu. Then:
- Select + New Flow from the top.
- Select Automated Cloud Flow.
- Name your flow.
- Select your flow’s trigger. This should be either When a new email arrives (V3) or When a new email arrives in a shared mailbox (V3).
- Select Create.
Start Your Flow
- Ensure the correct email is listed as the connection. If not, select the Change Connection button and add the required email.
- In the Include Attachments field, select Yes.
- Optionally, select Advanced Parameters, such as only forwarding emails from specific emails.
- Toggle off the New Designer toggle. This shows you the classic view of Power Automate where you can easily copy and paste the code view provided below into each of your actions.
Add Your Next Step
- Navigate to the My clipboard page.
- Paste the following into your clipboard:
{“id”:“ff85baab-26d8-46fd-bb98-e74cbe8c86bd”,“brandColor”:“#770BD6”,“connectionReferences”:{“shared_office365”:{“connection”:{“id”:“/providers/Microsoft.PowerApps/apis/shared_office365/connections/shared-office365-739780f9-1b2e-43d0-8252-65181efd9bbd”}}},“connectorDisplayName”:“Variables”,“icon”:“data:image/svg+xml;base64,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”,“isTrigger”:false,“operationName”:“Initialize_URL_variable”,“operationDefinition”:{“type”:“InitializeVariable”,“inputs”:{“variables”:[{“name”:“URL variable”,“type”:“string”,“value”:“https://apps.nextworld.net/webhooks/AppMainWorking/rlsmc/api/integrations/v1/webhooks/InboundEmailsWorking"}]},“runAfter”:{},“metadata”:{“operationMetadataId”:"e83aea25-742f-4ce7-b53a-b729c3280237”}}}
- Select Initialize URL variable.
Add Your Next Step
{“id”:“97b5dd0d-f037-40e1-8c7b-408d53f14f5d”,“brandColor”:“#770BD6”,“connectionReferences”:{“shared_office365”:{“connection”:{“id”:“/providers/Microsoft.PowerApps/apis/shared_office365/connections/shared-office365-739780f9-1b2e-43d0-8252-65181efd9bbd”}}},“connectorDisplayName”:“Variables”,“icon”:“data:image/svg+xml;base64,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”,“isTrigger”:false,“operationName”:“Initialize_Username_variable”,“operationDefinition”:{“type”:“InitializeVariable”,“inputs”:{“variables”:[{“name":“Username”,“type”:“string”,“value”:"salesreporttesting.salesmanagement@nextworld.net”}]},“runAfter”:{“Initialize_URL_variable”:[“Succeeded”]},“metadata”:{“operationMetadataId”:“14e1d43f-2e22-4b57-8a1f-03d4e0c63772”}}}
- Select Initialize Username variable.
Add Your Next Step
{“id”:“b12d170c-7239-4369-a962-f99ab3978910”,“brandColor”:“#770BD6”,“connectionReferences”:{“shared_office365”:{“connection”:{“id”:“/providers/Microsoft.PowerApps/apis/shared_office365/connections/shared-office365-739780f9-1b2e-43d0-8252-65181efd9bbd”}}},“connectorDisplayName”:“Variables”,“icon”:“data:image/svg+xml;base64,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”,“isTrigger”:false,“operationName”:“Initialize_Password_variable”,“operationDefinition”:{“type”:“InitializeVariable”,“inputs”:{“variables”:[{“name”:“Password”,“type”:“string”,“value”:“2wfM3^s@W#H23v^^eRVh”}]},“runAfter”:{“Initialize_Username_variable”:[“Succeeded”]},“metadata”:{“operationMetadataId”:“4374bd06-2c20-41a0-b2d4-e7e8293e2f63”}}}
- Select Initialize Password variable.
Add Your Next Step
{“id”:“16dcf093-1ead-4899-a0f1-dddf3cd04a3d”,“brandColor”:“#484F58”,“connectionReferences”:{“shared_office365”:{“connection”:{“id”:“/providers/Microsoft.PowerApps/apis/shared_office365/connections/shared-office365-739780f9-1b2e-43d0-8252-65181efd9bbd”}}},“connectorDisplayName”:“Control”,“icon”:“data:image/svg+xml;base64,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”,“isTrigger”:false,“operationName”:“Condition_-_If_email_has_attachment”,“operationDefinition”:{“type”:“If”,“expression”:{“and”:[{“equals”:[“@triggerOutputs()?[‘body/value’][0]?[‘hasAttachments’]”,“@true”]}]},“actions”:{“For_each_attachment”:{“type”:“Foreach”,“foreach”:“@triggerOutputs()?[‘body/value’][0]?[‘attachments’]”,“actions”:{“Parse_JSON_1”:{“type”:“ParseJson”,“inputs”:{“content”:{“UNSOMessageId”:“@{triggerOutputs()?[‘body/value’][0]?[‘id’]}”,“UNSORequestingEmail”:“@{triggerOutputs()?[‘body/value’][0]?[‘from’]}”,“UNSOEmailSubject”:“@{triggerOutputs()?[‘body/value’][0]?[‘subject’]}”,“UNSOEmailBody”:“@{triggerOutputs()?[‘body/value’][0]?[‘body’]}”,“UNSOUser”:“@{triggerOutputs()?[‘body/value’][0]?[‘toRecipients’]}”,“UNSOAttachmentId”:“@{item()?[‘id’]}”,“UNSOAttachmentName”:“@{item()?[‘name’]}”,“UNSOFileSize”:“@item()?[‘size’]”,“UNSOEmailTo”:“@{triggerOutputs()?[‘body/value’][0]?[‘toRecipients’]}”},“schema”:{“type”:“object”,“properties”:{“UNSOMessageId”:{“type”:“string”},“UNSORequestingEmail”:{“type”:“string”},“UNSOEmailSubject”:{“type”:“string”},“UNSOEmailBody”:{“type”:“string”},“UNSOUser”:{“type”:“string”},“UNSOAttachmentId”:{“type”:“string”},“UNSOAttachmentName”:{“type”:“string”},“UNSOFileSize”:{“type”:“integer”},“UNSOEmailTo”:{“type”:“string”}}}},“runAfter”:{},“metadata”:{“operationMetadataId”:“cc8f33e1-8f75-4e06-a303-4660c7091371”}},“HTTP”:{“type”:“Http”,“inputs”:{“method”:“POST”,“uri”:“@variables(‘URL variable’)”,“body”:{“UNSOMessageId”:“@{body(‘Parse_JSON_1’)?[‘UNSOMessageId’]}”,“UNSORequestingEmail”:“@{body(‘Parse_JSON_1’)?[‘UNSORequestingEmail’]}”,“UNSOEmailSubject”:“@{body(‘Parse_JSON_1’)?[‘UNSOEmailSubject’]}”,“UNSOEmailBody”:“@{body(‘Parse_JSON_1’)?[‘UNSOEmailBody’]}”,“UNSOUser”:“@{body(‘Parse_JSON_1’)?[‘UNSOUser’]}”,“UNSOEmailTo”:“@{body(‘Parse_JSON_1’)?[‘UNSOEmailTo’]}”,“UNSOEmailHasAttachment”:“@{triggerOutputs()?[‘body/value’][0]?[‘hasAttachments’]}”,“UNSOAttachmentId”:“@{body(‘Parse_JSON_1’)?[‘UNSOAttachmentId’]}”,“UNSOFileSize”:“@body(‘Parse_JSON_1’)?[‘UNSOFileSize’]”,“UNSOAttachmentName”:“@{body(‘Parse_JSON_1’)?[‘UNSOAttachmentName’]}”},“authentication”:{“type”:“Basic”,“username”:“@{variables(‘Username’)}”,“password”:“@{variables(‘Password’)}”}},“runAfter”:{“Parse_JSON_1”:[“Succeeded”]},“runtimeConfiguration”:{“contentTransfer”:{“transferMode”:“Chunked”}},“metadata”:{“operationMetadataId”:“c3611b74-2355-4986-b8ec-dbb749396554”}}},“runAfter”:{},“metadata”:{“operationMetadataId”:“b326ecfc-3c27-4f40-b928-5d336fe39d8e”}}},“runAfter”:{“Initialize_Password_variable”:[“Succeeded”]},“else”:{“actions”:{“Parse_JSON”:{“type”:“ParseJson”,“inputs”:{“content”:{“UNSOMessageId”:“@{triggerOutputs()?[‘body/value’][0]?[‘id’]}”,“UNSORequestingEmail”:“@{triggerOutputs()?[‘body/value’][0]?[‘from’]}”,“UNSOEmailSubject”:“@{triggerOutputs()?[‘body/value’][0]?[‘subject’]}”,“UNSOEmailBody”:“@{triggerOutputs()?[‘body/value’][0]?[‘body’]}”,“UNSOUser”:“@{triggerOutputs()?[‘body/value’][0]?[‘toRecipients’]}”,“UNSOEmailTo”:“@{triggerOutputs()?[‘body/value’][0]?[‘toRecipients’]}”},“schema”:{“type”:“object”,“properties”:{“UNSOMessageId”:{“type”:“string”},“UNSORequestingEmail”:{“type”:“string”},“UNSOEmailSubject”:{“type”:“string”},“UNSOEmailBody”:{“type”:“string”},“UNSOEmailTo”:{“type”:“string”},“UNSOUser”:{“type”:“string”}}}},“runAfter”:{},“metadata”:{“operationMetadataId”:“e4cf6176-8e9e-450e-9e6f-acf2a4aae53a”}},“HTTP_1”:{“type”:“Http”,“inputs”:{“method”:“POST”,“uri”:“@variables(‘URL variable’)”,“body”:{“UNSOMessageId”:“@{body(‘Parse_JSON’)?[‘UNSOMessageId’]}”,“UNSORequestingEmail”:“@{body(‘Parse_JSON’)?[‘UNSORequestingEmail’]}”,“UNSOEmailSubject”:“@{body(‘Parse_JSON’)?[‘UNSOEmailSubject’]}”,“UNSOEmailBody”:“@{body(‘Parse_JSON’)?[‘UNSOEmailBody’]}”,“UNSOEmailTo”:“@{body(‘Parse_JSON’)?[‘UNSOEmailTo’]}”,“UNSOUser”:“@{body(‘Parse_JSON’)?[‘UNSOEmailTo’]}”,“UNSOEmailHasAttachment”:“@{triggerOutputs()?[‘body/value’][0]?[‘hasAttachments’]}”},“authentication”:{“type”:“Basic”,“username”:“@{variables(‘Username’)}”,“password”:“@{variables(‘Password’)}”}},“runAfter”:{“Parse_JSON”:[“Succeeded”]},“runtimeConfiguration”:{“contentTransfer”:{“transferMode”:“Chunked”}},“metadata”:{“operationMetadataId”:“a8f5a6b4-8411-4a62-a14c-4d621f6bbc8b”}}}},“metadata”:{“operationMetadataId”:“2809b3d0-3d1f-452a-aab2-72496beb8e82”}}}
- Select Condition - If email has attachment.
Next Steps
Once your Power Automate flow is created and saved, you must configure OAuth. Learn more in Configure OAuth for Outlook Attachments (Microsoft Graph) (IDP-Email forwarding) Power Automate Setup for forwarding emails WITH ATTACHMENTS into the platform
