(IDP-Email forwarding) Power Automate Setup for forwarding emails WITHOUT ATTACHMENTS into the platform
This configuration is part of the email forwarding feature available for the platform. This configuration step occurs after you:
  • Configure your Webhook Setup record in the Nextworld platform. Learn more in the Automate email forwarding with webhooks topic in Nextworld Help.
This configuration document provides shortcuts for creating a flow. There are code snippets provided which you can copy and paste into each action in order to recreate a flow created and tested by internal development. Once created, you can edit and change any components.
Power Automate Configuration for Emails without Attachments
Navigate to Power Automate and select My Flows from the Sidebar menu. Then:
  1. Select + New Flow from the top.
  2. Select Automated Cloud Flow.
  3. Name your flow.
  4. Select your flow’s trigger. This should be either When a new email arrives (V3) or When a new email arrives in a shared mailbox (V3).
  5. Select Create.
Start Your Flow
  1. Ensure the correct email is listed as the connection. If not, select the Change Connection button and add the required email.
  2. Optionally, select Advanced Parameters, such as only forwarding emails from specific emails.
  3. Toggle off the New Designer toggle. This shows you the classic view of Power Automate where you can easily copy and paste the code view provided below into each of your actions.
Add Your Next Step
  1. Navigate to the My clipboard page.
  2. Paste the following into your clipboard:
{“id”:“ff85baab-26d8-46fd-bb98-e74cbe8c86bd”,“brandColor”:“#770BD6”,“connectionReferences”:{“shared_office365”:{“connection”:{“id”:“/providers/Microsoft.PowerApps/apis/shared_office365/connections/shared-office365-739780f9-1b2e-43d0-8252-65181efd9bbd”}}},“connectorDisplayName”:“Variables”,“icon”:“data:image/svg+xml;base64,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”,“isTrigger”:false,“operationName”:“Initialize_URL_variable”,“operationDefinition”:{“type”:“InitializeVariable”,“inputs”:{“variables”:[{“name”:“URL variable”,“type”:“string”,“value”:“https://apps.nextworld.net/webhooks/AppMainWorking/rlsmc/api/integrations/v1/webhooks/InboundEmailsWorking"}]},“runAfter”:{},“metadata”:{“operationMetadataId”:"e83aea25-742f-4ce7-b53a-b729c3280237”}}}
  1. Select Initialize URL variable.
Add Your Next Step
{“id”:“97b5dd0d-f037-40e1-8c7b-408d53f14f5d”,“brandColor”:“#770BD6”,“connectionReferences”:{“shared_office365”:{“connection”:{“id”:“/providers/Microsoft.PowerApps/apis/shared_office365/connections/shared-office365-739780f9-1b2e-43d0-8252-65181efd9bbd”}}},“connectorDisplayName”:“Variables”,“icon”:“data:image/svg+xml;base64,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”,“isTrigger”:false,“operationName”:“Initialize_Username_variable”,“operationDefinition”:{“type”:“InitializeVariable”,“inputs”:{“variables”:[{“name":“Username”,“type”:“string”,“value”:"salesreporttesting.salesmanagement@nextworld.net”}]},“runAfter”:{“Initialize_URL_variable”:[“Succeeded”]},“metadata”:{“operationMetadataId”:“14e1d43f-2e22-4b57-8a1f-03d4e0c63772”}}}
  1. Select Initialize Username variable.
Add Your Next Step
{“id”:“b12d170c-7239-4369-a962-f99ab3978910”,“brandColor”:“#770BD6”,“connectionReferences”:{“shared_office365”:{“connection”:{“id”:“/providers/Microsoft.PowerApps/apis/shared_office365/connections/shared-office365-739780f9-1b2e-43d0-8252-65181efd9bbd”}}},“connectorDisplayName”:“Variables”,“icon”:“data:image/svg+xml;base64,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”,“isTrigger”:false,“operationName”:“Initialize_Password_variable”,“operationDefinition”:{“type”:“InitializeVariable”,“inputs”:{“variables”:[{“name”:“Password”,“type”:“string”,“value”:“2wfM3^s@W#H23v^^eRVh”}]},“runAfter”:{“Initialize_Username_variable”:[“Succeeded”]},“metadata”:{“operationMetadataId”:“4374bd06-2c20-41a0-b2d4-e7e8293e2f63”}}}
  1. Select Initialize Password variable.
Add Your Next Step
{“id”:“8d9eb1af-3148-42dd-b821-c99cb990e3a1”,“brandColor”:“#8C6CFF”,“connectionReferences”:{“shared_office365”:{“connection”:{“id”:“/providers/Microsoft.PowerApps/apis/shared_office365/connections/shared-office365-739780f9-1b2e-43d0-8252-65181efd9bbd”}}},“connectorDisplayName”:“Data Operations”,“icon”:“data:image/svg+xml;base64,PHN2ZyB2ZXJzaW9uPSIxLjEiIHZpZXdCb3g9IjAgMCAzMiAzMiIgeG1sbnM9Imh0dHA6Ly93d3cudzMub3JnLzIwMDAvc3ZnIj4NCiA8cGF0aCBmaWxsPSIjOEM2Q0ZGIiBkPSJtMCAwaDMydjMyaC0zMnoiLz4NCiA8ZyBmaWxsPSIjZmZmIj4NCiAgPHBhdGggdHJhbnNmb3JtPSJtYXRyaXgoLjggMCAwIC44IDMuMTk4IDIuNjczKSIgZD0iTTYgMTYuMDdhMi4yNCAyLjI0IDAgMCAwIC45LS4xOSAyLjM2IDIuMzYgMCAwIDAgMS4yNC0xLjI0IDIuMjIgMi4yMiAwIDAgMCAuMTktLjl2LTEuMjlhOC4yMiA4LjIyIDAgMCAxIDAtMS4yNiA0LjY4IDQuNjggMCAwIDEgLjMtMS4xOSAzLjA5IDMuMDkgMCAwIDEgLjcxLTEgMy40MiAzLjQyIDAgMCAxIDEuMTQtLjc1IDMuNTEgMy41MSAwIDAgMSAxLjM0LS4yNnYxLjExYTIuMjEgMi4yMSAwIDAgMC0uOS4xOSAyLjM2IDIuMzYgMCAwIDAtMS4yNCAxLjI0IDIuMjMgMi4yMyAwIDAgMC0uMTkuOXYyYTcgNyAwIDAgMS0uMDkuOTMgMy43MyAzLjczIDAgMCAxLS4yNS44NiAzLjI3IDMuMjcgMCAwIDEtLjQ3Ljc4IDMuNDQgMy40NCAwIDAgMS0uNzcuNjkgMy40OCAzLjQ4IDAgMCAxIC43Ny42OSAzLjI5IDMuMjkgMCAwIDEgLjQ3Ljc4IDMuNzUgMy43NSAwIDAgMSAuMjUuODYgNyA3IDAgMCAxIC4wOS45M3YyYTIuMjIgMi4yMiAwIDAgMCAuMTkuOSAyLjM3IDIuMzcgMCAwIDAgMS4yMyAxLjE1IDIuMjIgMi4yMiAwIDAgMCAuOS4xOXYxLjE2YTMuNDkgMy40OSAwIDAgMS0xLjM0LS4yNiAzLjQxIDMuNDEgMCAwIDEtMS4xNC0uNzUgMy4wOSAzLjA5IDAgMCAxLS43MS0xLjA2IDQuNjcgNC42NyAwIDAgMS0uMjktMS4xOCA4LjI0IDguMjQgMCAwIDEgMC0xLjI2di0xLjI5YTIuMjMgMi4yMyAwIDAgMC0uMTktLjkgMi4zNSAyLjM1IDAgMCAwLTEuMjQtMS4yMyAyLjIyIDIuMjIgMCAwIDAtLjktLjE4em0xNC4xOS04LjEzYTMuNTEgMy41MSAwIDAgMSAxLjM0LjI2IDMuNDIgMy40MiAwIDAgMSAxLjEzLjggMy4wOSAzLjA5IDAgMCAxIC43MSAxIDQuNjggNC42OCAwIDAgMSAuMjkgMS4xOSA4LjIyIDguMjIgMCAwIDEgMCAxLjI2djEuMjlhMi4yMiAyLjIyIDAgMCAwIC4xOS45IDIuMzcgMi4zNyAwIDAgMCAxLjI0IDEuMjQgMi4yMiAyLjIyIDAgMCAwIC45LjE5djEuMTZhMi4yMSAyLjIxIDAgMCAwLS45LjE5IDIuMzYgMi4zNiAwIDAgMC0xLjI0IDEuMjQgMi4yMyAyLjIzIDAgMCAwLS4xOS45djEuMjlhOC4yNCA4LjI0IDAgMCAxIDAgMS4yNiA0LjY3IDQuNjcgMCAwIDEtLjI5IDEuMTggMy4wOSAzLjA5IDAgMCAxLS43MSAxLjA2IDMuNDEgMy40MSAwIDAgMS0xLjE0Ljc1IDMuNDkgMy40OSAwIDAgMS0xLjM0LjI2di0xLjE1YTIuMjQgMi4yNCAwIDAgMCAuOS0uMTkgMi4zNiAyLjM2IDAgMCAwIDEuMjQtMS4yNCAyLjIyIDIuMjIgMCAwIDAgLjE5LS45di0yYTcgNyAwIDAgMSAuMDctLjg4IDMuNzUgMy43NSAwIDAgMSAuMjUtLjg2IDMuMjkgMy4yOSAwIDAgMSAuNDctLjc4IDMuNDggMy40OCAwIDAgMSAuNzctLjY5IDMuNDQgMy40NCAwIDAgMS0uNzgtLjY3IDMuMjcgMy4yNyAwIDAgMS0uNDctLjc4IDMuNzMgMy43MyAwIDAgMS0uMjUtLjg2IDcgNyAwIDAgMS0uMDktLjkzdi0yYTIuMjMgMi4yMyAwIDAgMC0uMTktLjkgMi4zNSAyLjM1IDAgMCAwLTEuMjQtMS4yNCAyLjIyIDIuMjIgMCAwIDAtLjktLjE5di0xLjE2eiIvPg0KICA8cGF0aCB0cmFuc2Zvcm09Im1hdHJpeCguOCAwIDAgLjggMy4xOTggMi42NzMpIiBkPSJNMjAuMTIgMTRhMS4yOSAxLjI5IDAgMCAxLS4wOS40OCAxLjIxIDEuMjEgMCAwIDEtLjI4LjQybC01IDUtMi4zOS42LjY0LTIuNCA1LTVhMS4yNSAxLjI1IDAgMCAxIC40Mi0uMjggMS4yOSAxLjI5IDAgMCAxIC40OC0uMDkgMS4yMiAxLjIyIDAgMCAxIC40OS4xIDEuMjcgMS4yNyAwIDAgMSAuNjcuNjcgMS4yMiAxLjIyIDAgMCAxIC4wNi41em0tNy4wNyA1LjhsMS4yNC0uMzFhMS4yMiAxLjIyIDAgMCAwLS45My0uOTN6bS41Ny0xLjY4YTEuNzIgMS43MiAwIDAgMSAxLjExIDEuMTFsNC4wOC00LjA4LTEuMTEtMS4xMXptNS41My0zLjMybC4xOC0uMThhMS4zNyAxLjM3IDAgMCAwIC4xNi0uMTguNzguNzggMCAwIDAgLjExLS4yLjcyLjcyIDAgMCAwIDAtLjI1Ljc2Ljc2IDAgMCAwLS4wNi0uMy43OC43OCAwIDAgMC0uMTctLjI1LjgzLjgzIDAgMCAwLS4yNS0uMTcuNzYuNzYgMCAwIDAtLjMtLjA2LjcyLjcyIDAgMCAwLS4yNSAwIC44Mi44MiAwIDAgMC0uMi4xMWwtLjE4LjE2LS4xOS4yNXoiIHN0cm9rZT0iI2ZmZiIgc3Ryb2tlLW1pdGVybGltaXQ9IjEwIiBzdHJva2Utd2lkdGg9Ii4yNSIvPg0KIDwvZz4NCjwvc3ZnPg0K”,“isTrigger”:false,“operationName”:“Parse_JSON”,“operationDefinition”:{“type”:“ParseJson”,“inputs”:{“content”:{“UNSOMessageId”:“@{triggerOutputs()?[‘body/id’]}”,“UNSORequestingEmail”:“@{triggerOutputs()?[‘body/from’]}”,“UNSOEmailSubject”:“@{triggerOutputs()?[‘body/subject’]}”,“UNSOEmailBody”:“@{triggerOutputs()?[‘body/body’]}”,“UNSOEmailTo”:“@{triggerOutputs()?[‘body/toRecipients’]}”,“UNSOUser”:“@{triggerOutputs()?[‘body/toRecipients’]}”},“schema”:{“type”:“object”,“properties”:{“UNSOMessageId”:{“type”:“string”},“UNSORequestingEmail”:{“type”:“string”},“UNSOEmailSubject”:{“type”:“string”},“UNSOEmailBody”:{“type”:“string”},“UNSOEmailTo”:{“type”:“string”},“UNSOUser”:{“type”:“string”}}}},“runAfter”:{},“metadata”:{“operationMetadataId”:“e4cf6176-8e9e-450e-9e6f-acf2a4aae53a”}}}
  1. Select Parse JSON.
Add Your Next Step
{“id”:“71101885-8151-46d0-b3b6-fa55f7cd397b”,“brandColor”:“#709727”,“connectionReferences”:{“shared_office365”:{“connection”:{“id”:“/providers/Microsoft.PowerApps/apis/shared_office365/connections/shared-office365-739780f9-1b2e-43d0-8252-65181efd9bbd”}}},“connectorDisplayName”:“HTTP”,“icon”:“data:image/svg+xml;base64,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@variablesC0xLjUyN3pNMTEuOTY0IDIxLjY3M2gxLjUyN3YxLjM4MmgtMS41Mjd6TTE1LjIzNiAyMy40MThoMS4zODJ2LjU4MmgtMS4zODJ6Ii8+DQogPC9nPg0KPC9zdmc+DQo=”,“isTrigger”:false,“operationName”:“HTTP_1”,“operation@variablesefinition”:{“type”:“Http”,“in@variablesuts”:{“method”:“POST”,“uri”:“@variables(‘URL variable’)”,“body”:{“UNSOMessageId”:“@{body(‘Parse_JSON’)?[‘UNSOMessageId’]}”,“UNSORequestingEmail”:“@{body(‘Parse_JSON’)?[‘UNSORequestingEmail’]}”,“UNSOEmailSubject”:“@{body(‘Parse_JSON’)?[‘UNSOEmailSubject’]}”,“UNSOEmailBody”:“@{body(‘Parse_JSON’)?[‘UNSOEmailBody’]}”,“UNSOEmailTo”:“@{body(‘Parse_JSON’)?[‘UNSOEmailTo’]}”,“UNSOUser”:“@{body(‘Parse_JSON’)?[‘UNSOEmailTo’]}”,“UNSOEmailHasAttachment”:“@{triggerOutputs()?[‘body/hasAttachments’]}”},“authentication”:{“type”:“Basic”,“username”:“@{variables(‘Username’)}”,“password”:“@{variables(‘Password’)}”}},“runAfter”:{“Parse_JSON”:[“Succeeded”]},“runtimeConfiguration”:{“contentTransfer”:{“transferMode”:“Chunked”}},“metadata”:{“operationMetadataId”:“a8f5a6b4-8411-4a62-a14c-4d621f6bbc8b”}}}
  1. Select HTTP 1.
