Is there an easy way to see where endpoint definitions are being called in logic blocks?
Ok, so it looks like the No-Code Studio is quite handy for doing “where used“ searches.
You could use Asset Usage Inquiry and search on the Action Name “Call External Endpoint”. It would give you list of Logic Blocks using the action. It does not show you which one though, you’d have to drill into each LB or make some inferences on the LB name.
I think it would be nice to have a view of where endpoint definitions are called in logic blocks. I will enter an idea.
