Some customers may have a need to print multiple copies of a label template design across a single label or sheet. One common target might be the letter tray for a LaserJet printer, which can be designed to print name tags, sheets of bin labels, and other varying use cases.
Product Release/Version
All EPP Build Versions Support Multi-Up printing.
Sample printout produced with EPP 10.1.1.5 and using a PCL-to-PDF converter to generate a visual reference.
Multi-Up Sample
Each EPP installation includes a sample label template that demos this feature, the ‘NameBadge.laser.lbl’ template.
When considering the ‘Page Size’ and label sizes, the “safe area” for most LaserJet printers is usually a 0.5" top margin and 0.25" left, right, and bottom margins.
The ‘Margins to Origin’ are additional padding applied to the printers “safe area”, and will not usually result in “borderless” printing behavior, unless your LaserJet printer has that feature enabled by default.
Multi-Up Printing
If you send a multi-label print for a multi-up label template, then EPP will produce an output like the below example.
ULD Batch Print Sample
/L=#Samples\Employee\NameBadge.laser.lbl /C=1 /P=defaultSite#FauxPrinter
/DR=FirstName+LastName+TelephoneNumber+EMail+HomepageURL+BirthYear+BirthMonth+BirthDay+AddressLine1+City+State+Zip+Title
Thaddeus~Venture~303-996-6844~doctorventure@VentureIndustries.org~www.VentureIndustries.org~1960~7~17~1 Venture Way~Colorado Springs~CO~80132~Super Scientist
Dean~Venture~303-401-0037~DeanVenture@VentureIndustries.org~~1987~6~12~1 Venture Way~Colorado Springs~CO~80132~Boy Adventurer
Hank~Venture~303-248-6329~hank_thebat@BizzyBeeFanClub.net~~1987~6~12~1 Venture Way~Colorado Springs~CO~80132~Boy Adventurer
Brock~Samson~202-912-8661~brock.samson@osi.gov~~1962~5~28~2 Venture Way~Colorado Springs~CO~80132~Agent 92-62
Malcom~Fitzcarraldo~973-306-4657~TheMonarch@goci.org~www.GuildofCalamitousIntent.com/TheMightyMonarch.info~1960~7~17~601 Dr Martin Luther King Jr Blvd~Newark~NJ~7102~The Blue Morpho
Courtney~Haine~859-553-3425~SergeantHatred@VentureIndustries.org~~1670~11~4~1 Venture Way~Colorado Springs~CO~80132~Bodyguard
Dr. Byron~Orpheus~505-646-8617~byron.orpheus@orderofthetriad.org~www.OrderOfTheTriad.org/contactus~1958~4~18~1 Venture Way~ Apt B~Colorado Springs~CO~80132~Sorcerer
XML Batch Print Sample
<?xml version="1.0" encoding="UTF-8" standalone="no"?>
<!DOCTYPE labels SYSTEM "dsi-label.dtd">
<labels _FORMAT="#Samples\Employee\NameBadge.laser.lbl" _PRINTERNAME="defaultSite#HP-M603" _QUANTITY="1">
<label _FORMAT="#Samples\Employee\NameBadge.laser.lbl" _PRINTERNAME="defaultSite#HP-M603" _QUANTITY="1">
<variable name="FirstName">George</variable>
<variable name="LastName">Washington</variable>
<variable name="TelephoneNumber">555-867-5309</variable>
<variable name="EMail">George.Washington@WhiteHouse.gov</variable>
<variable name="HomepageURL">www.whitehouse.gov</variable>
<variable name="BirthYear">1732</variable>
<variable name="BirthMonth">02</variable>
<variable name="BirthDay">22</variable>
<variable name="AddressLine1">3200 Mount Vernon Memorial Highway</variable>
<variable name="City">Mount Vernon</variable>
<variable name="State">VA</variable>
<variable name="Zip">22309</variable>
<variable name="Title">President of the United States</variable>
</label>
<variable name="FirstName">Thaddeus</variable>
<variable name="LastName">Venture</variable>
<variable name="TelephoneNumber">303-996-6844</variable>
<variable name="EMail">doctorventure@VentureIndustries.org</variable>
<variable name="HomepageURL">www.VentureIndustries.org</variable>
<variable name="BirthYear">1960</variable>
<variable name="BirthMonth">07</variable>
<variable name="BirthDay">17</variable>
<variable name="AddressLine1">1 Venture Way</variable>
<variable name="City">Colorado Springs</variable>
<variable name="State">CO</variable>
<variable name="Zip">80132</variable>
<variable name="Title">Super Scientist</variable>
</label>
<variable name="FirstName">Dean</variable>
<variable name="TelephoneNumber">303-401-0037</variable>
<variable name="EMail">DeanVenture@VentureIndustries.org</variable>
<variable name="HomepageURL"/>
<variable name="BirthYear">1987</variable>
<variable name="BirthMonth">06</variable>
<variable name="BirthDay">12</variable>
<variable name="Title">Boy Adventurer</variable>
</label>
<variable name="FirstName">Hank</variable>
<variable name="TelephoneNumber">303-248-6329</variable>
<variable name="EMail">hank_thebat@BizzyBeeFanClub.net</variable>
</label>
<variable name="FirstName">Brock</variable>
<variable name="LastName">Samson</variable>
<variable name="TelephoneNumber">202-912-8661</variable>
<variable name="EMail">brock.samson@osi.gov</variable>
<variable name="BirthYear">1962</variable>
<variable name="BirthMonth">05</variable>
<variable name="BirthDay">28</variable>
<variable name="AddressLine1">2 Venture Way</variable>
<variable name="Title">Agent 92-62</variable>
</label>
<variable name="FirstName">Malcom</variable>
<variable name="LastName">Fitzcarraldo</variable>
<variable name="TelephoneNumber">973-306-4657</variable>
<variable name="EMail">TheMonarch@goci.org</variable>
<variable name="HomepageURL">www.GuildofCalamitousIntent.com/TheMightyMonarch.info</variable>
<variable name="AddressLine1">601 Dr Martin Luther King Jr Blvd</variable>
<variable name="City">Newark</variable>
<variable name="State">NJ</variable>
<variable name="Zip">7102</variable>
<variable name="Title">The Blue Morpho</variable>
</label>
<variable name="FirstName">Courtney</variable>
<variable name="LastName">Haine</variable>
<variable name="TelephoneNumber">859-553-3425</variable>
<variable name="EMail">SergeantHatred@VentureIndustries.org</variable>
<variable name="BirthYear">1670</variable>
<variable name="BirthMonth">11</variable>
<variable name="BirthDay">04</variable>
<variable name="Title">Bodyguard</variable>
</label>
<variable name="FirstName">Dr. Byron</variable>
<variable name="LastName">Orpheus</variable>
<variable name="TelephoneNumber">505-646-8617</variable>
<variable name="EMail">byron.orpheus@orderofthetriad.org</variable>
<variable name="HomepageURL">www.OrderOfTheTriad.org/contactus</variable>
<variable name="BirthYear">1958</variable>
<variable name="BirthMonth">04</variable>
<variable name="BirthDay">18</variable>
<variable name="City"> Apt B</variable>
<variable name="State">Colorado Springs</variable>
<variable name="Zip">CO</variable>
<variable name="Title">80132</variable>
</label>
</labels>
Printed Results Sample
