Missing required field error on UnitsOfMeasure table while required field is populated
Receiving a system error on save on the UnitOfMeasureGroup field, UnitsOfMeasure table while it is populated. I can also see in dev tools that the field has the value I set. I have regenerated the app and refreshed the table with not luck, how do I get around this?
Summary
This text will be hidden
Summary
Summary
This seems like a bug to me, I recommend creating a customer support ticket.
Not an error - the Units of Measure list lookup value needed a dependent lookup value.
Good stuff, glad you know what was causing this! Seems like there should be a bug here with reverse dependent list lookups causing a confusing user experience when the Dependent Value is left empty.
I think the error just needs to be a little bit more clear since to set up unit of measure, you need to populate the table and the list lookup, making sure that the dependent lookup value is populated
Agreed, here’s what I’ve asked for:
After you enter UOM = Each* you get an error because the Reverse Table Lookup configuration specified between UnitOfMeasureGroup and UnitOfMeasure on the underlying UnitsOfMeasure table cannot be resolved due to a missing Dependent Value for Each* on the Units of Measure list lookup
