Pulling audit on deleted record
We have a customer who accidentally deleted a record. Is there a way to run a table audit for deleted records?
You can use the Audit History Generation Utility in conjuction with Audit History Viewer to generate full audit histories of audited tables which will include record deletions.
You will need a role such as SYS - Record Audit and additional table level security to see these results as the information that this surfaces can be sensitive, so that role should not be widely granted.
Nextworld Help has more information on these apps.
Is there any way to recover the deleted record to maintain the same nwId? @ian.p
@jess it is not possible today to recover deleted records. There is an idea in Nextworld’s backlog for this which I’m tagging this post to.
