RN-25.1-[Core]-5110
Action Required Details
If you have any owned or customized objects using these tables or views, review the changed items made to the tables that might impact the functionality and uptake the changes.
If you have any owned or copied interactive reports built over the table or view, review the changed items made to the table or view that might impact the functionality and uptake the change.
Description of Issue
We have created a story about removing deprecated fields from various directory tables. I wanted to double check if the fields themselves are being deprecated. I am wondering if there are additional steps I can take?
Steps Taken
Based on the Action Required Details above and the Release Notes RN-25.1-[Core]-5110.
  • I have checked the tables for customizations and did not see any.
  • I have checked the copied from and verified we do not have any nsCox-tables copied from these NW tables listed in the Release Notes.
  • I have checked the Interactive Report Builder and have not found any reports built directly on the tables.
We can remove this. No longer needed.
@connor.hoffman Here is a link to the NW Help documentation we created for the directory overhaul. If you have questions after reviewing the documentation, we can set up a time to meet.
