Sizing of Interactive Reports as Dashboard Cards
Hi there
Is there a way to specify the paging/default # rows on an interactive report used on dashboard cards?
It look as though mini apps load 10 records in the dashboard cards, whereas, the interactive reports load 50. If you have a mix of mini apps and interactive report dashboard cards, the size of the dashboard cards differs substantially.
Thank you.
Hi Claire! Interactive Reports has a new feature that lets you set the default page sizing on report versions. This should be live in 25.1 and later. Right now, the smallest option, “small”, is about 25 records depending on the query of your report. We can certainly investigate adding even smaller paging sizes.
Excellent, thank you @calvin.fisher !
