Subtable Row Fields Enable/Disable
Is there anyway to enable or disable fields on a subtable by Row? For example, if a field on the subtable row has a value, we then want to disable other fields on that row. If that same field is empty, we want to enable other fields on that row.
I tried looping through subtable and disabling based on a field and it will disable it, but when you try to ADD a new row those same fields are all disabled. So the enable/disable is applying to all rows in the subtable.
Any work around ideas or is this an enhancement request?
There is not right now. It’s all or nothing. This would be an enhancement.
